the following error appears when adding friction to surface behavior in contact interaction (for any model) in the newest v1.4.0 dev version:
Details:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Collections.Generic.KeyNotFoundException: The given key was not present in the dictionary.
at System.ThrowHelper.ThrowKeyNotFoundException()
at System.Collections.Generic.Dictionary`2.get_Item(TKey key)
at PrePoMax.Forms.ListViewItemComparer.Compare(Object x, Object y)
at System.Windows.Forms.ListView.CompareFunc(IntPtr lparam1, IntPtr lparam2, IntPtr lparamSort)
at System.Windows.Forms.UnsafeNativeMethods.CallWindowProc(IntPtr wndProc, IntPtr hWnd, Int32 msg, IntPtr wParam, IntPtr lParam)
at System.Windows.Forms.NativeWindow.DefWndProc(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ListView.WndProc(Message& m)
at UserControls.ListViewWithSelection.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.8.4614.0 built by: NET48REL1LAST_B
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
PrePoMax
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///E:/PrePoMax%20v1.4.0%20dev/PrePoMax.exe
CaeGlobals
CodeBase: file:///E:/PrePoMax%20v1.4.0%20dev/lib/CaeGlobals.DLL
Win32 Version: 4.8.4550.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
Win32 Version: 4.8.4605.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
Win32 Version: 4.8.4390.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
UserControls
CodeBase: file:///E:/PrePoMax%20v1.4.0%20dev/lib/UserControls.DLL
vtkControl
Assembly Version: 1.0.8536.27130
CodeBase: file:///E:/PrePoMax%20v1.4.0%20dev/lib/vtkControl.DLL
System.Configuration
Win32 Version: 4.8.4190.0 built by: NET48REL1LAST_B
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
Win32 Version: 4.8.4084.0 built by: NET48REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
CaeMesh
CodeBase: file:///E:/PrePoMax%20v1.4.0%20dev/lib/CaeMesh.DLL
CaeModel
CodeBase: file:///E:/PrePoMax%20v1.4.0%20dev/lib/CaeModel.DLL
UnitsNet
Win32 Version: 4.0.0.0
CodeBase: file:///E:/PrePoMax%20v1.4.0%20dev/lib/UnitsNet.DLL
Kitware.VTK
Assembly Version: 5.8.0.607
Win32 Version: 5.8.0.607
CodeBase: file:///E:/PrePoMax%20v1.4.0%20dev/lib/Kitware.VTK.DLL
Kitware.mummy.Runtime
Assembly Version: 1.0.2.599
Win32 Version: 1.0.2.599
CodeBase: file:///E:/PrePoMax%20v1.4.0%20dev/lib/Kitware.mummy.Runtime.DLL
WindowsBase
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
CaeJob
CodeBase: file:///E:/PrePoMax%20v1.4.0%20dev/lib/CaeJob.DLL
CaeResults
CodeBase: file:///E:/PrePoMax%20v1.4.0%20dev/lib/CaeResults.DLL
System.ValueTuple
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ValueTuple/v4.0_4.0.0.0__cc7b13ffcd2ddd51/System.ValueTuple.dll
NCalc
Assembly Version: 1.3.8.0
Win32 Version: 1.3.8.0
CodeBase: file:///E:/PrePoMax%20v1.4.0%20dev/lib/NCalc.DLL
ZedGraph
Assembly Version: 5.1.7.430
Win32 Version: 5.1.7.430
CodeBase: file:///E:/PrePoMax%20v1.4.0%20dev/lib/ZedGraph.DLL
Accessibility
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
