Im using the Calculix Keyword edtior to define a compression only Material, to “simulate” concrete. This works reasonably well at the moment. However i need to consider the weight/gravity of the concrete, therefor i need to define the density of the compression only material.
Is this even possible ? and if yes, what kind of units do I have to use, Prepomax uses t/mm^3, does Calculix use that aswell ?
