Hi i have problems simulating this cylindrical vessel, am having a non positive jacobian error and i could not find the solution to my problem in the forum
Am using the axisymmetric for this simulation, sorry if the solution is obvious ![]()
In axisymmetric models, all faces must lie to the right of the Y axis. That’s most likely why the left part of your geometry has this error.
If you want to simulate a complete vessel, rotate it so that Y axis is the axis of symmetry - that’s what CalculiX expects.
Also, you should refine the mesh significantly.
Thanks so muchhhhh i will try!!
Not sure if this is the same issue @FEAnalyst , but I’m trying to create a simple axisymmetric cylinder.
When I generate the mesh, I get a warning message.
At first, I ignored it and the simulation ran with results.
Then I tried flipping the face normals on my CAD model and ran the simulation again, but this time I got a non-positive Jacobian error.
Is it safe to ignore the initial warning, or could it affect the results? IS there a better way to process ? I joined you my geometry normaly I take care to make it right with the axes setup.
If you are running an axisymmetric analysis, you have to make sure that:
This has to be corrected in order to avoid such errors. Negative jacobians in 2D models are a typical sign that the normals are pointing in the wrong direction.
