Could someone please take a look and let me know if I am on the right track? I am a designer, am new to PrePoMax/mechanical engineering in general.
Recently I made a model for an installation and want to do a test in PrePoMax to see how it stands in general. After some research, this is what I ended up with:
Material is wood fused PLA and has 3 properties assigned: elasticity, plasticity, density. Numbers are given by manufacturer. The “light material” is lighter because it’s hollow inside, so I give it a smaller density to simplify the problem. Step is static with iterative cholesky solver, 5s time period, 1s initial time increment, 1e -6s min increment. The goal of analysis is to see if there’s any point that has very high stress - something approximate is good enough, the model is already a simplified version of the original.
Besides the settings above, I’ve also tried other solvers, increments, or a model that is one single piece instead of 4 pieces, and I never get a result that converges. Anything I am missing?
