I am currently planning to perform a thermal stress analysis. When entering the material properties, I would like to define the material properties as temperature-dependent, so that their values change according to changes in temperature.
However, it appears that the coefficient of thermal expansion cannot be defined as a temperature-dependent property.
Is there any way to input temperature-dependent values for the coefficient of thermal expansion? I am currently considering thermal stress changes associated with phase transformations in metals, and I would like to define the coefficient of thermal expansion in greater detail as a function of temperature.
I have installed the latest version, v2.6.2 dev, but as shown in the attached screenshot, even after checking “Use temperature-dependent data points,” the temperature field does not appear.
Are you testing this using an older version?
There are no issues with the other material property fields.
