Greetings!
I want to simulate bolt connectors in a simple plate tension test. How to do this in prepomax?
There’s no such predefined feature but you could define a beam element (through keyword editor because beams are not supported in GUI yet) and connect it to the rest of the model via rigid body constraints:
Thank you! i will check this out
I’m currently testing another way using DCOUP3D elements to mimic Rbe3 behavior. In the following screenshots, contact surfaces have been defined between the screw heads and the plate, but also between the plates themselves => in other words, the plates are only maintained by the contact.
However i’m facing 2 issues when applying temperature:
*ERROR in envtemp:
*****number of network equations is not equal to
number of active degrees of freedom*****
# of network equations = 18
# of active degrees of freedom= 679
Anybody would have recognized the FEAnalyst model (tutorial)
Still investigating …
HI Paul18fr
Is your model constrained in any way in the z direction?
Regards
EDITED: Try to define the DCOUP 3D element initial temperatures with custom cards. It might be a problem similar to the one with compresion only in thermal analisys.
Strange, such errors should normally happen for 1D fluid elements: Hydraulic analysis with split and joint - CalculiX (official versions are on www.calculix.de, the official GitHub repository is at https://github.com/Dhondtguido/CalculiX).
But I guess DCOUP3D elements are indeed the culprit here.
@ANYS: on the screw only, but not the plates.
Hare the 2 slave nodes are free following Z
Note the current model is a test : model link
(link available only 24 hours from now)
Thanks.
I wasn’t able to preload without fixing at least one point in preload direction as you. Not big deal here.
I have finished recently the performance check of a similar model. Not detailed stresses at threads or heads, just overall tensile at the bolt shank and Contact preload pressure. FEA result compared against analytical calculation (*). Very good results.
My goal is now to check the Bolt Preload Change Due to Temperature. I got a “simple” example with analitical solution and methodology if you are interested. It would be applicable to your model so you could check your aproach performance. I’m using the model described in here as reference:
(*) VDI 2230 methodology as described in the book “Introduction to the Design & Behavior of Bolted Joints” by John H. Bickford
that’s i would like to do too, but i’m facing difficulties (see previous post); if you’ve a look to the thermal expansion of the materials, the one of the bolt is twice of the plates => the tightening should decrease accordingly.
ÂżHow do you Know?
In the current model, with an uniform temperature and a screw that expands more than the plates => obviously the tightening (force) decreases …
That’s true if the system is free to expand. But,… you have fixed the bottom and the preload reference node. That space in beteeen is not expanding freely.
you’re right for the current BCs ![]()
