Best way to model center of gravity
Looking to see if there’s a way to create a node at some defined location and then apply forces to it (which is connected to the model by some rigid link elements). Would remote load option be best for this? I also was looking to see if we can choose where the rigid elements connect to the model? Ideally connecting the link from the mass node to where fasteners are in the model.
This is typically done using a rigid body constraint. You can place its reference point anywhere. When creating it, choose “Center of gravity” and specify a set which should be used to determine this location.
