Rigid body on the base and imposed rotation by means of an amplitude.
Amplitude can be read to it’s equivalent angle.
Rigid body on the tip with point mass on the ref.
You can extract displacement of the ref .
You can validate your set up by rotating a hallow tube (Less elements than solid and same inertia in all directions). Ref node deflection should remain constant during a full rotation.
Additionally, use a base material which doesn’t have density defined. It makes it easier to verify results using hand calculations.
What still feels odd to me is that gravity can be applied only partially in Prepomax. Other softwares doesn’t even ask about that. I can’t imagine a situation where it applies but…
It is true that the load is called gravity, but it is actually an acceleration load. The acceleration load is not necessarily constant or active on all mesh elements. So maybe a special case could be created for gravity, where all elements would be affected.
