Adding mass to the Part/Assembly query
Hi, would be great to have computed also the mass of a part based in the density and thikness for shell components!
Regards
Here’s how the mass query works in Abaqus:
  • it takes into account shell, solid, truss, and point/nonstructural mass elements
  • missing thickness, density, or section assignment is excluded from mass calculations
  • variable thickness assignments are not taken into account
  • shell offset values are not considered when calculating the center of volume or surface area
  • the mass query evaluates mass distributed in a continuum throughout the model, while the solver calculates the mass properties according to the discretization of the model
Since the integration is already built in, adding mass computation to solids is easy. I will see how to implement it for shells when an offset is involved. The computation will be based on finite element discretization.
