When meshing solids imported from STEP created in FreeCAD, the “Quad-dominated” option does not work for me. This is independent of the PrePoMax version. Does anyone have an idea what affects the use of a cuboid mesh?
Quad-dominated works for surface meshes only - it tries to replace triangular elements with quadrilateral ones. If you want a hexahedral 3D mesh for a solid, you should use one of the Gmsh algorithms: Summary of Gmsh hex meshing rules
// Gmsh Option File
// This file contains configuration options (preferences) that
// are loaded each time Gmsh is launched. You can create this
// file by hand, or let Gmsh generate it for you (with
// ‘File->Save Default Options’). This file can also be
// automatically saved every time you quit Gmsh if the option
// ‘General.SaveOptions’ is set.
General.Axes = 3;
General.BoundingBoxSize = 2.82842712474619;
General.DoubleBuffer = 0;
General.DrawBoundingBoxes = 1;
General.GraphicsFontSize = 16;
Geometry.OCCFixDegenerated = 1;
Geometry.OCCFixSmallEdges = 1;
Geometry.OCCFixSmallFaces = 1;
Geometry.Surfaces = 1;
Geometry.Volumes = 1;
Mesh.ElementOrder = 2;
Mesh.HighOrderOptimize = 2;
Mesh.MeshSizeMax = 1;
Mesh.MeshSizeFromCurvature = 1;
Mesh.MinQuality = 1e+200;
Mesh.OptimizeNetgen = 1;
Mesh.RecombinationAlgorithm = 2;
Mesh.SaveGroupsOfNodes = 1;
Mesh.Smoothing = 100;
Mesh.SurfaceEdges = 0;
Mesh.VolumeFaces = 1;
i checked again in menus to generate hex-dominant mesh, it seems some option is missing in Mesh.Recombine3DAll to be activated (yes/1) instead of default (no/0). Another meshing algorithm setting also in 2D R-Tree options.
