*WARNING in gentiedmpc: no tied MP
I tried giving both bodies the same temperature but to no avail, I independently defined temperature of all bodies and kept it same, but the problem still persists. As for defining final temp in Defined Fields, the option says that it is not possible to edit that
What type of step is that ? Still uncoupled temperature-displacement ? The defined temperature field can be used only in purely mechanical analyses.
It worked! thank you so much you’re a lifesaver!
