Hi all,
does anyone know a way to visualize user defined coordinate systems or the local coordinate system of elements? This would be convinient to check if the orientations are defined correctly.
Thanks a lot for any hint!
Hi all,
Local coordinate systems are not yet supported in PrePoMax.
If I understood correctly, CS is not supported in GUI. However, user/local CS could be applied manually by adding CalculiX keywords.
In my 1/8 case study, I applied *Transform to introduce cylindrical CS.
Correct me if I am wrong.
Yes, it can be defined using keywords. But the question is about visualizing it and that’s not yet possible.
