Is this a ccx limitation?
It shouldn’t be a matter of the step number but its type. Is it some dynamic step ?
1Static. Deactivated
2Buckling.Deactivated
3Frequency (*)
Even erasing the first step I’m not allawed.
Even if a save it as a new file and erase the first two steps.
(*) I fill like Bill Murray right now.
Guess why.
Loads can’t be defined in frequency steps, also in Abaqus:
Oh. Thanks. I have to split right.
Pre-stress + second step with frequency and active Perturbation.
Can I use any load (Pressure) or is there any concern about it.?
Yes, you need two separate steps: https://www.youtube.com/watch?v=-M2BOHHkUf4
Any load type should work.
Thank you. It worked fine
