So I’ve made a simulation with the first 1000 modes. It took almost 2.5 hours.
In the resulting frd-files there is a lot of data for each mode, but I’ve failed to make anything useful of it apart from getting the actual modes by evaluating non-zero U3 results.
I tried several automatic metrics based on the FRD data, including maximum U3 displacement, RMS(U3), percentage of active nodes and U3 dominance. None of these metrics correlated well with what visually appears to be an acoustically relevant membrane mode in PrePoMax.
If I group them together within 10 Hz I get:
(python file included here:frd_cruncher.zip (1.5 KB))
Main Mode Frequency(Hz) Mode Members
1 320.00 1
2 509.87 2,3
4 540.54 4,5
6 683.38 6,7
8 700.52 8
9 734.53 9
10 848.98 10,11,12,13
14 933.54 14,15
16 975.66 16,17
18 1002.17 18,19,20
21 1120.05 21,22
23 1131.85 23,24
Where the frequency is of the first mode in the mode members group, just to get the list shorter.
Here’s the whole file:Tweeter-PEN_Modes.zip (3.8 KB)
I suspect that many of these modes or groups of modes are of no interest, as they probably have too little acoustic impact/amplitude. As I understand it, PrePoMax only shows the mode with no realistic U3 amplitudes. In fact, many of them are just “flat”:
While others clearly resonate in U3
In a modal analysis of a thin membrane, how can one automatically identify the modes that are acoustically significant and exclude modes that mainly represent in-plane motion or local numerical buckling effects?
And for the SMACK membrane: Which modes are most likely to create distortion because the conductors move through regions of non-uniform magnetic flux density?
