Hello everyone,
I have been following this forum for some time and have learned a lot from it. Although I deal with engineering problems on a daily basis, I am not an FEM expert. I would appreciate your feedback on the correctness of my approach, the quality of the performed FEM analyses, and the validity of the conclusions. Below is a lengthy description of the problem with details for those interested:
Long_discription.zip (2.2 MB)
The subject of this study is a real structural failure that occurred during operation, involving a fracture near of a welded joint. Three FEM models were analyzed:
· Solution A – original design (failed in service),
· Solution B – reinforced welded joint,
· Solution C – reinforced joint with reduced number and diameter of relief holes.
All files PMX, results in doc:
Linear for all solutions, non-linear, and quasi-plastic limit analyses for A solution were performed. The results suggest that the structure does not fail due to static overload, and fatigue is considered the most probable failure mechanism. That was confirmed after initial inspections.
Below are the questions I would like to discuss, along with the relevant data:
1. Is the mesh quality sufficient?
2. Why does the Quasi-Plastic Limit Analysis (A) show the highest plastic strain (PE = 0.284) in the displacement area rather than near the welded joint (PE = 0.227)? Is this result correct?
3. Have the analyses been performed correctly?
4. In your opinion, are the conclusions valid?
5. Are there any serious errors in the analyses?
6. What suggestions would you give to improve such analyses in future steel structure assessments?
Mesh
Mesh_Salome_graph.zip (190.0 KB)
Damage image
Results of the Quasi-Plastic Limit Analysis in the graphs
This is my first post on this topic, so please bear with me and feel free to offer suggestions on how to improve future posts.
Best Regards
