Simplified bolt connection with beam element and rigid constraints
Reducing the contact stiffness may help too, especially if this method yields significantly (by orders of magnitude) lower value than the default: Snap-fit contact snagging problem - #17 by JuanP74 - Analysis issues - CalculiX (official versions are on www.calculix.de, the official GitHub repository is at https://github.com/Dhondtguido/CalculiX).
And it’s sometimes beneficial to remove friction (although it cuts both ways since friction may help avoid rigid body motions, but only once contact is properly established).
