Simplified bolt connection with beam element and rigid constraints
Thank you so much for your help this morning!
Here is my model :
I’ve reached the following stage in my .inp file:
** Heading +++++++++++++++++++++++++++++++++++++++++++++++++
*Heading
Hash: DNXQftHo, Date: 03/10/2026, Unit system: MM_TON_S_C
** Nodes +++++++++++++++++++++++++++++++++++++++++++++++++++
*Node
... hidden data ...
25965, 0, 0, 0
** Elements ++++++++++++++++++++++++++++++++++++++++++++++++
*Element, Type=C3D10, Elset=B
... hidden data ...
*Element, Type=C3D10, Elset=A
... hidden data ...
*Element, Type=B32, Elset=EBolt0
9614, 25964, 25965, 25966
** Node sets +++++++++++++++++++++++++++++++++++++++++++++++
*Nset, Nset=head
... hidden data ...
*Nset, Nset=nut
... hidden data ...
*Nset, Nset=Internal-1_sHead
... hidden data ...
*Nset, Nset=Internal-1_sNut
... hidden data ...
*Nset, Nset=Internal_Selection-1_Fixed-1
... hidden data ...
*Nset, Nset=force
... hidden data ...
*Nset, Nset=Internal-1_sForce
... hidden data ...
*Nset, Nset=cA
... hidden data ...
*Nset, Nset=cB
... hidden data ...
*Nset, Nset=Internal-1_sCA
... hidden data ...
*Nset, Nset=Internal-1_sCB
... hidden data ...
** Additional node sets ++++++++++++++++++++++++++++++++++++
... hidden data ...
** Element sets ++++++++++++++++++++++++++++++++++++++++++++
*Elset, Elset=Internal-1_sHead_S4
... hidden data ...
*Elset, Elset=Internal-1_sHead_S1
... hidden data ...
*Elset, Elset=Internal-1_sHead_S3
... hidden data ...
*Elset, Elset=Internal-1_sHead_S2
... hidden data ...
*Elset, Elset=Internal-1_sNut_S1
... hidden data ...
*Elset, Elset=Internal-1_sNut_S4
... hidden data ...
*Elset, Elset=Internal-1_sNut_S2
... hidden data ...
*Elset, Elset=Internal-1_sNut_S3
... hidden data ...
*Elset, Elset=Internal-1_sForce_S3
... hidden data ...
*Elset, Elset=Internal-1_sForce_S2
... hidden data ...
*Elset, Elset=Internal-1_sForce_S4
... hidden data ...
*Elset, Elset=Internal-1_sForce_S1
... hidden data ...
*Elset, Elset=Internal-1_sCA_S1
... hidden data ...
*Elset, Elset=Internal-1_sCA_S2
... hidden data ...
*Elset, Elset=Internal-1_sCA_S4
... hidden data ...
*Elset, Elset=Internal-1_sCA_S3
... hidden data ...
*Elset, Elset=Internal-1_sCB_S2
... hidden data ...
*Elset, Elset=Internal-1_sCB_S1
... hidden data ...
*Elset, Elset=Internal-1_sCB_S3
... hidden data ...
*Elset, Elset=Internal-1_sCB_S4
... hidden data ...
*Elset, Elset=Internal_Selection-1_Solid_Section-1
... hidden data ...
** Surfaces ++++++++++++++++++++++++++++++++++++++++++++++++
*Surface, Name=sHead, Type=Element
Internal-1_sHead_S4, S4
Internal-1_sHead_S1, S1
Internal-1_sHead_S3, S3
Internal-1_sHead_S2, S2
*Surface, Name=sNut, Type=Element
Internal-1_sNut_S1, S1
Internal-1_sNut_S4, S4
Internal-1_sNut_S2, S2
Internal-1_sNut_S3, S3
*Surface, Name=sForce, Type=Element
Internal-1_sForce_S3, S3
Internal-1_sForce_S2, S2
Internal-1_sForce_S4, S4
Internal-1_sForce_S1, S1
*Surface, Name=sCA, Type=Element
Internal-1_sCA_S1, S1
Internal-1_sCA_S2, S2
Internal-1_sCA_S4, S4
Internal-1_sCA_S3, S3
*Surface, Name=sCB, Type=Element
Internal-1_sCB_S2, S2
Internal-1_sCB_S1, S1
Internal-1_sCB_S3, S3
Internal-1_sCB_S4, S4
** Physical constants ++++++++++++++++++++++++++++++++++++++
** Coordinate systems ++++++++++++++++++++++++++++++++++++++
** Materials +++++++++++++++++++++++++++++++++++++++++++++++
*Material, Name=S355
*Density
7.8E-09
*Elastic
210000, 0.28
*Expansion, Zero=20
1.1E-05
*Conductivity
14
*Specific heat
440000000
** Sections ++++++++++++++++++++++++++++++++++++++++++++++++
*Solid section, Elset=Internal_Selection-1_Solid_Section-1, Material=S355
*Beam Section, elset=EBolt0, material=S355, section=CIRC
8.0
1,0,0
 ** M16
*EQUATION
2
25964,1,1.,1,1,-1.
2
25964,2,1.,1,2,-1.
2
25964,3,1.,1,3,-1.
*EQUATION
2
25966,1,1.,2,1,-1.
2
25966,2,1.,2,2,-1.
2
25966,3,1.,2,3,-1.
** Pre-tension sections ++++++++++++++++++++++++++++++++++++
** Constraints +++++++++++++++++++++++++++++++++++++++++++++
*Rigid body, Nset=Internal-1_sHead, Ref node=25964, Rot node=25965
*Rigid body, Nset=Internal-1_sNut, Ref node=25966, Rot node=25967
*Rigid body, Nset=Internal-1_sForce, Ref node=25968, Rot node=25969
** Surface interactions ++++++++++++++++++++++++++++++++++++
*Surface interaction, Name=Surface_Interaction-1
*Surface behavior, Pressure-overclosure=Linear
10000000, 2.86
*Friction
0.1
** Contact pairs +++++++++++++++++++++++++++++++++++++++++++
*Contact pair, Interaction=Surface_Interaction-1, Type=Surface to surface
sCB, sCA
** Amplitudes ++++++++++++++++++++++++++++++++++++++++++++++
** Initial conditions ++++++++++++++++++++++++++++++++++++++
** Steps +++++++++++++++++++++++++++++++++++++++++++++++++++
** Step-1 ++++++++++++++++++++++++++++++++++++++++++++++++++
*Step
*Static
** Controls ++++++++++++++++++++++++++++++++++++++++++++++++
** Output frequency ++++++++++++++++++++++++++++++++++++++++
** Boundary conditions +++++++++++++++++++++++++++++++++++++
*Boundary, op=New
** Name: Fixed-1
*Boundary
Internal_Selection-1_Fixed-1, 1, 6, 0
** Loads +++++++++++++++++++++++++++++++++++++++++++++++++++
*Cload, op=New
*Dload, op=New
** Name: Concentrated_Force-1
*Cload
25968, 3, -50000
** Defined fields ++++++++++++++++++++++++++++++++++++++++++
** History outputs +++++++++++++++++++++++++++++++++++++++++
** Field outputs +++++++++++++++++++++++++++++++++++++++++++
*Node file
RF, U
*El file
S, E, NOE
** End step ++++++++++++++++++++++++++++++++++++++++++++++++
*End step
Should I enable NL geom?
