For new created materials in v2.0.8, entered yield stress values will not be converted correct to other unit systems, when the created material will be loaded from the material library.
As shown, only the first line will be converted correctly:
I will look into it ![]()
I can confirm the bug.
Edit: I think (hope, pray) that I finally solved this problem. The fix will be available in the next release.
Thanks. Maybe it is (was) the same cause for the bug described here
It was the same problem.
Version 2.0.10 contains the fix. Did it help?
Yes, the values seem to be converted correctly for newly defined materials and for old ones i added long before v2.0.8. So it doesn’t work for materials created with v2.0.8 - they must be deleted and re-entered (and maybe versions shortly before that, I can no longer test that).
Ok, thank you. I will close this topic since it works for materials created in the newest developer version.
