Dear PrePoMax team,
I would put together two simulation in one: press fit of gear on shaft (through command Defined fields + Tie Constraint) and meshing load (external loads on X, Y and Z direction).
I would perform on Step1 the press fit; then on Step2 the meshig load calculation.
My questions is the following: when performing the Step2, shall I keep the press fit through as well as the other boundary conditions as a Copy & Paste of previous Step1, or are those automatically inherited from previous Step1?
Thank you in advance for your support.
Regards, Umberto
