We are designing a motor side cap for the electric motor. The model is attached (step file).
We are planning to mount 6304 bearings. Radial load on the bearing is 2.4kN ( motor rpm ~10000)
We want to understand the maximum load the motor side cap can handle before it gets deformed. We are planning to use Al 6xxx or 7xxx series
To make it more realistic, you could split that surface of the hole into two regions and apply pressure or traction load only to one half because the bearing won’t pull the other side. A similar approach is shown in the video linked above.
