I have a confusion about doing modal analysis of a rotating shaft, the results came out that the frequency at mode 2 is 0Hz which seems incorrect in my opinion.
my project is in this link:
I still cannot figured out what part did I do wrong according to all the setups I made?
I have a different problem with this file - I don’t see any geometry or mesh when I open it in v1.3.4.
Something is off with units here. You seem to be using the SI(m) system. But Young’s modulus should be higher: 210000000000 Pa if it’s steel. Then the rotational speed is around 1047.2 rad/s - is that correct ?
And finally - when I measure the model from exported .inp file, the length of the shaft is 1305 m. So it seems that you imported the geometry without scaling. You can do it in CAD software before exporting or in PrePoMax with Model → Part → Transform → Scale.
Before you run the full 2-step analysis, try just the static or frequency step and see if the displacements, stresses or frequencies make sense.
Yes, unscaled geometry, unit mismatch and Young’s modulus a few orders of magnitude too low. In the model I shared, this is corrected but you should still run these two steps separately (like I did with a frequency step) and see if the results make sense. Only then proceed to full multi-step analysis (preloaded eigenfrequency extraction).
I’ve already tried the edited file, and the results are exactly what I was hoping for.
I apologize if I’ve asked a lot of questions — I’m a graduated high school student and will going to first-year undergraduate school soon, but I really want to practice using CalculiX and hope it will benefit me in the future.
When I want to work in SI(m) system with model created in FreeCAD and exported to STEP, I have to scale it in FreeCAD first before exporting. As I’ve mentioned above, PrePoMax also has scaling. And, in addition to Query → Distance, it also has a convenient ruler at the bottom that allows you to estimate the size of the model.
