Usually, I always use the latest PrePoMax versions. Still, every time another one is released I need to update the default settings again (such as the number of processors, background color, undeformed colors, and so on…) and even though this is not a great problem, it would be nice to carry the defaults for the next release. Is there a way of doing this?
Can’t this procedure crash something else in the software? Or is it a safe way to transfer the settings? For now, I already changed everything to my preferences manually, but I will try it in the next versions.
The proposed method should work in most cases. If a new setting is added it might not be set to the correct default value if the file is copied. The problem might occur if I change or rename some settings. This will not happen often.
