Heat Pulsed power
Hi to everybody.
Is there a method to give an heat pulsed to an object?
For example, 10 seconds at 10 W/mm^2,
then 10 seconds at 0 W/mm^2 (OFF),
then 10 seconds at 10 W/mm^2,
and so on.
Thank you to all.
Giovanni
Yes, you can use the amplitude feature for that. Create new tabular amplitude and assign it to load (surface heat flux in this case). Just keep in mind that the units are mW/mm^2.
Ooooh my God.
That’s Fatntastic.
Thank you very Much!!!
PrePoMax is THE BEST !!!
Thank you
Giovanni
This approach is used in one of my github examples:
