Hi, I’m looking to choose between two AMD processors for a new workstation build. I’m trying to choose between a Ryzen 9 9950X and a Ryzen 9 7950X3D (see screenshot)
- Both are 16 core processors, nominally the 9950 runs at 4.3 GHz and the 7950 runs at 4.2 GHz
- Both have 16MB L2 cache
- The 7950 has 128MB L3 cache while the 9950 has 64MB
- The 9950 is approximately $110 cheaper at the moment
Which will translate to better real-world FEA performance, assuming all else is equal? Does L3 cache have a significant effect on FEA performance? Does this change with single versus multicore processing?
(important to note - I’ll be using a mix of commercial and open-source FEA codes. The commercial codes are significantly cheaper to run with only 4-cores, though I’d consider paying for HPC licenses to use all 16 cores. The open source codes will use all cores.)
Thank you!
