This command convert all the solid part into shell, but I don’t understand witch kind of surface the sw take into consideration (outer - mid - inner); because I tried to push the button but (apart from the tree bar) the solid remain phisically the same.
Is there anybody that can answer this question? Because I looked in the forum but I wasn’t able to find this specific topic.
The conversion uses all visible/ouside surfaces of a solid to create the shell. And takes a closed shell to create a body. In these conversions, the geometry does not change.
Yes, extract midsurfaces (or only top or bottom surfaces, but then you should define offset for shell section in PrePoMax) from each part in CAD software, export to STEP and import to PrePoMax.
I’ve extracted from CAD file the mid surface of every single pieces and import it in PPM.
Last clarification: why there is this simbol “!” on that parts?
Thank you for your explaination. Do you think that could be better to manually detect the tie contact between the parts (instead of automatically detection)?
Automatic detection work really well and tries to merge redundant ties, but of course, it may not be able to properly resolve all cases when there are multiple parts connecting in the same region. Then you can always correct it manually - remove redundant constraints, merge them or swap master/slave assignments where necessary.
Following your suggestion I tried to match manually the Tie contact (with less numbers of items instead automatically check). Now seems to work properly
Of course, you may still need to have a closer look at the joints to see if they are connected at the whole perimeter without any gaps or mesh distortions.
Not necessarily, these Joints are new features based on rigid body or coupling constraints and because of known CalculiX limitations, they may not work well with shells (unless they are manually extruded to solids). They could lead to overconstraints as well, but you can try them if you want, possibly on a small segment of the model first.
Tie constraints should suffice, but what I meant is that you may need to examine each connection between parts to see if these constraints work as expected. Modal analysis is a good way to facilitate such checks, but visual inspection may help too.
