Compression only contact
i’m having some issues setting up a compression only contact.
I have a steel outer sheath (Blue), surrounding a steel pile (Green), there is an 80mm gap between them that is filled with concrete (red). This will then be bolted together between pile and sheath to take the vertical load on the pile.
The connection is under a vertical load and a bending moment. I want to know the pressure in the concrete where in contacts the pile (green to red connection) but considering the concrete only acting in compression.
For simplicity I have made the bolted studs as part of the concrete solid body.
Sheath to concrete (blue to red) is tied:
Concrete to pile (including studs) is as linear :
I originally tried a hard contact and then re-run it as linear, annoyingly I saved over the old results so only have the linear results to present, but they were much the same.
Contact details
k= 10000000 N/mm³
Stress infinity = 2.86 MPa
Co = Default
The analysis takes over 1hr to run
These are the stress distribution in the pile:
And the stress distribution on the concrete:
Below is the same model and load used in the autocad inventor stress analysis tool with the contact only connection above set to “separation”
This stress magnitude and distribution is much more in line with what I was expecting.
any idea What am I doing wrong with PrePoMax? I’m happy to upload a model if it helps
The compression-only constraint works better with lower contact stiffnesses. So it is always better to start with a lower value and then increase it to fix the penetration.
There is a compression-only elasticity model in CalculiX, but it requires keyword edits: https://www.youtube.com/watch?v=z5IQuXv8A2Q
Contact stiffness often needs to be reduced to aid convergence. It can be estimated using this approach: Snap-fit contact snagging problem - #17 by JuanP74 - Analysis issues - CalculiX (official versions are on www.calculix.de, the official GitHub repository is at https://github.com/Dhondtguido/CalculiX).
Hard contact internally is just linear contact with the default constants. The default stiffness is the Young’s modulus of the first material in the input deck multiplied by 50.
For accurate contact stress results, it would be best to mesh the cylindrical parts with linear hex elements. You could use sweep or extrusion technique for that. This usually provides much smoother contact pressure distribution. Of course, you may need to refine the mesh too, it looks rather coarse globally (the question is also what mesh was used in Inventor).
Theoretically, you could also try Mortar contact for even more accurate results, but it’s likely to cause non-convergence and needs the newest CalculiX version available (2.23 at the moment) to work well enough.
Thanks,
this is the new result using the contact only material type:
This is a much more believable result, i will now run with a finer mesh. i need to read up on the pros and cons of different mesh types, it would be handy to have a video on that.
is there a way of defining this behaviour as a contact type? it would be helpful
Do you mean compression-only elasticity added via Keyword Editor ?
Finer and with hex elements if possible (but you would need to remove the small holes from the cylinders).
I only have an article about hex meshes and element selection in CalculiX written in Polish, but some tips can be found in the CalculiX manual in the chapter on each element type.
In short words, for contact analyses, use linear hex (C3D8R) whenever possible and C3D10 when hex elements can’t be generated.
There is so-called compression-only constraint, but it’s not meant for contact between two parts. Instead, it’s a one-way support - it’s applied to a face to resist compression, but not tension.
Contact is inherently unidirectional (doesn’t resist tension and allows separation), but there is a way (workaround) to model it as no separation contact (only sliding is possible): No separation contact - CalculiX (official versions are on www.calculix.de, the official GitHub repository is at https://github.com/Dhondtguido/CalculiX).
Finally, there’s tied contact and tie constraints - they don’t allow any relative motions so they prevent both separation and sliding.
yes i, used the Keyword Editor here
I have tried to change the stiffness of the linier contact FEAnalyst suggested :
L_char I assume is the contact length, half the circumference of the pile = 960mm
So 0.5*(210000+25000)/960 = 123 N/mm^3
Results in the pile is now:
The compression only material results:
The biggest improvement came from increasing the mesh density. The compression only material gave much closer results with the less dense mesh.
The compression only material analysis appears to be acting with friction as the connecting studs are not loaded in shear
No, it’s a characteristic average length of finite elements in the contact regions. So it should be much smaller - you would have to roughly measure some elements as shown in the snap-fit screenshot.
