No, OP=NEW only removes all the BCs that were not respecified within the step. It’s not that it removes the previous BCs defined in the same step.
Oooh. Thanks.
Jakub
Would be nice one of those in Prepomax:
Which one? You can deactivate the BCs in any step. You can also propagate the BCs to the following steps.
I guess that ANYS is talking about the BC Manager itself. It’s a handy tool but yes - deactivation and propagation of selected BCs is still possible in PrePoMax. It’s just handled differently in the input deck - Abaqus uses the default OP=MOD if nothing is deactivated in a step.
I found the OP=MOD setting a little confusing for new users. If there are 2 steps and the same load is defined in the three (in both steps), then looking at the .inp file shows a different picture. The load is suddenly missing. So I decided to redefine everything.
In which cases does the OP=NEW couses problems?
Yeah, it makes sense as the default setting. Normally, it shouldn’t cause any problems. But CalculiX has its quirks: Wrong results in a multistep analysis with shells and *BOUNDARY, OP=NEW · Issue #13 · Dhondtguido/CalculiX · GitHub
