Matej
March 23, 2025, 8:59am
1
A new release version of the PrePoMax contains the following FEM features (with regard to v2.2.11):
Added support for zooming while doing rubber band selection
Added support for entering multiple IDs during mesh-based selection
Added support to specify gap in compression only constraint
The list of all new features can be found at: Version 2.3.0 – PrePoMax
Great news! The site still is unnavailable (at least from Argentina), is there any alternative to download?
For me, the website is working but alternative downloads are still provided here: PrePoMax website - #2 by Matej
The website is also not available in Malaysia also, but the problem is solved for me by using VPN.
Matej
March 24, 2025, 8:49am
5
I am really sorry for that but it seems after the cyber attack, our IT people are not capable/willing to open the site.
Could you post maybe the full list of changes that you mention in the announce? Thanks in advance.
Matej
March 24, 2025, 3:11pm
7
This is a copy from the PrePoMax home page: https://prepomax.fs.um.si/version-2-3-0/
Updated the mortar contact models
Added the number of edges and faces to the query surface tool
Added support for amplitudes by radiation emissivity and film coefficient
Added support for splitting periodic CAD surfaces during CAD file import
Added support for parameters to all initial conditions
Added support for imported ST load
Added support for initial angular velocity
Added support for sweep meshing
Added support for defeaturing CAD parts: Geometry → CAD Part → Defeature
bug fixes
Added support for entering multiple IDs during mesh bsed selection
Added support for Run history file
Added support for Open/Save command history
Added support for Drag/Drop history commands
Added support to run postprocessing commands
Added support to reorganize history commands
Added support for execution times of history commands
Added colors to history commands view with two coloring options
Added CalculiX output to the output during command line regeneration.
Added regions field in all mesh setup items
Added support for highlighting items in trees and list-views on mouse move
Added symbols for defined fields
Added symbols for initial conditions
bug fixes
Matej
March 27, 2025, 6:28am
8
I got a reply that now the web page should be available from all over the world Can you @SergioP1975 check for Argentina and you @blue_ray for Malaysia?
arnie
March 27, 2025, 12:05pm
9
Now it’s accessible from South Africa too !
Thank you @Matej
Also working from Argentina, thanks @Matej !
It works from Colombia as well.
Matej
March 28, 2025, 10:11am
12
Great, finally. It only took some months…
It’s working here in Malaysia, thank you very much
I am getting this error every time I open a file in 2.3.0.
Now it is accessible from Dubai. Thank you
Matej
March 30, 2025, 7:32pm
16
Did you put PrePoMax to a non-system and non-admin folder?
I put the Prepomax in C drive in a normal folder C:\FEA\Prepomax 2.3.0. Should I give admin privileges to the .exe??
Matej
March 30, 2025, 8:39pm
18
The folder you are using should work. .exe does not need any admin privileges.
So you can import the geometry and set up the model but opening a file does not work? Can you check your work directory at Tools → Settings → CalculiX
waluyo
April 6, 2025, 5:21am
19
Thank you, now I can confirm, the website is now accessible from Indonesia.
leon
May 14, 2025, 5:29am
20
Thank you, the website is now accessible from China.
