In this version:
- History editor was added to the Edit menu
- the bug causing PrePoMax to become very slow was fixed
- some smaller bugs exterminated
The history editor enables viewing of the history and deleting selected command entries by selecting the first column of the row and using the delete key. The entire history can be deleted using the Clear button.
Changing the history will change the Regenerate functionality, so use it cautiously. Clearing a very long history might help with the responsiveness of PrePoMax since the history is saved to a file after each new command is added to it - after each feature is added to the model. A feature added to the model results in some text being added to the output textbox.
Download: Downloads β PrePoMax
