Slow to converge, or failing?
Tie constraints (inherited by CalculiX from Abaqus) work like welded/bonded contact in other software (prevent any relative motion - sliding and separation) but are implemented differently. They don’t use the contact algorithm. Unlike the tied contact type (also available in Abaqus) that has the same effect but uses contact elements and thus increase the size of the model.
Regular (e.g. hard or linear) contact in CalculiX allows for both separation and sliding. You can control the behavior in the normal and tangential directions separately (instead of predefined contact types available in some other FEA software). The latter allows you to specify a friction coefficient (otherwise, it’s frictionless). However, CalculiX doesn’t have rough contact (no sliding) and no separation modes available in Abaqus. Those require more manual workarounds.
It was actually created in a newer version. It will open in 2.1.11 dev.
this ran for me based on your original model without the pretension added, but with contact tied (needs to be changed to an overclosure method) , Gunnar’s additions show the direction to completion and it will run quick if you reduce the element order.
I’ve downloaded Gunnar’s model ok
No - have never used Creo. My FEA experience to date has been
  • Brief experience of the old Algor DesignCheck
  • a little know system called 3g.author which has some very nice ease of use features, but the company was bought by Autodesk and the product killed some years ago. This did use P & H refinement (automatic) if I recall correctly.
  • have tried FEMDesigner, but have always struggled to get it to solve anything except the examples provided with it.
  • have tried to use CAELinux , even bought a book which claimed to be a training manual for Salome - but it was not helpful.
is there any example test case from external software references? it seems tied contact implementation in CalculiX have advantages over another. Stiffness in normal and transversal direction can be set, thus make it possible to model fully bonded, separation (normal), sliding (shear) and partial composite actions in flat and curved surfaces.
It would be easier to replace them by compression only constraints:
Compression against ‘empty space’ ? How does that work? - not intuitive. Doesn’t the face have to have something to compress against?
I haven’t found where to set that up yet - probably just too busy tearing my hair out.
This may be much more versatile - but only if you can find it, and know how to use it.
The idea of the compression-only constraint is that you don’t have to model the rigid surface. Internally, it uses GAP elements (simple contact elements - spring-like) whose opposite nodes are grounded. They can be even visualized. You just set their (spring) stiffness.
Surface interaction settings give you this flexibility. Surface behavior is for the normal direction, Friction is for the tangential direction. GUI options are described in the PrePoMax documentation but to learn how all those settings work, you can refer to the CalculiX User’s Manual: https://www.dhondt.de/ccx_2.22.pdf
Even Abaqus documentation and tutorials can be helpful due to similar syntax.
It converges slowly. I’ve stretched the bolts as it was quicker to do than add the pretension.
i has been discussed in CalculiX forum, it may have similar to cohesive zone model except in limit or damage.
maybe a new thread is needed to discuss separately, simple example to do comparison taken from CalculiX example as officially recommended. All results should be consistent with constraint generated by ‘areampc 123’ and ‘areampc slide’ command in CGX. Additional of external software e.g Abaqus or Ansys as reference is highly appreciating to clarify about the implementation.
Thanks again Trevor.
I think I see how you ‘stretched the bolts’ in Step 1.
I’m confused by the field outputs NF,EF,CF -
Results only show Step 1 - I don’t see any way to find results for Step 2 ; hope I’m missing something simple…
Definitely ran to completion for me
you only need the nodal output NF and the contact output CF
I assumed the pins were pins and not bolts, that may or may not be correct.
There is something wrong with the results in the .pmx file so an error gets thrown. I fixed the error handling but the results are still empty.
I’m using 2.1.11 now.
I re-ran Trevor’s file - it converged, but again when I view the results only step 1 is shown - no sign of step 2.
The report when/after running included step 2.
I must be missing something - can anyone suggest what?
Convergence file is output for all steps?
Finally spotted something - Step numbers from set up do not match step numbers in results!!
There was a STEP 0 in results with only 1 increment in the results (but only showed briefly and now I can’t access it again). Now back to only Step #1 showing with 8 increments. I can’t believe this can be made so difficult.
I don’t know where to check for convergence files - but the monitor window when running did show step 1 then step 2. When I revert to it now, it only shows step 1 (with 10 increments).
Have set it running again in desperation…
What shows your step/increment bar?
s
In the temp folder, you’ll find all outputs saved
