Hi guys,
is there any option to “correct” the “missing” material in a midsurface modelled nozzle connection?
When I made the CAD model, everything looked nice.
Thank you much ![]()
nozzle_shell.pmx (6.4 MB)
Hi guys,
Do you mean the Missing_section-1 element set ? It’s still in the tree but you can delete it. Apparently, you had missing section assignment but corrected it. Now it runs
Hi! For me you have to release radial displacements at the pipe edges
Hi FEAnalyst,
I meant the marked area - there is like a socketed connection, however I modelled it as a fully inserted nozzle.
Hi Andrea,
I just made this model for play around and figure out the path forward. Is here any radial constraint - like in Ansys or I have set-up something individually at the constranins?
To avoid such effects at the connections of shell sections, you could model that area with solid elements and attach them (via tie constraint or tied contact: https://www.youtube.com/watch?v=Kc9Ln8zn3PE) to shell elements of the remaining portion of the pipe. This approach is quite common when accurate representation of nozzle connection is needed.
Or you could even try shell-to-solid submodeling. It seems to be supported in CalculiX: https://www.youtube.com/watch?v=RNVE1rk1yps
New versions of PrePoMax support boundary conditions in local coordinate systems (also cylindrical): https://www.youtube.com/watch?v=F9j0iEf3_4o
