Postprocessing: load factor contour plot
I also think that a more general way is the way to go. So in the next versions, support for equation based user-defined fields will be added. Whit this, the user could easily create a safety factor/load factor plot. The only problem with this procedure is that it operates on the whole mesh = all materials. So some additional functionality is needed in case there multiple materials are used.
