Opposite side extrusion of sketches
Ok, I thought you made the set after extrusion, but you did it before that (when it was still a shell mesh). So you just needed a translated copy.
I checked it before, but it can be hard to decipher when there are some undos/edits and you can’t regenerate it at the selected step.
indeed, history recording all action and below i build from start imported step files to clearly show about the process.
imprint2Dmesh.pmx (51.0 KB)
ps. to change refine the mesh, simple call ‘Regenerate History by Remeshing’ in menus and define maximum element size.
Yeah, it’s all clear now. The Thicken Shell Mesh tool as well as the standard hex meshing tools can achieve quite a lot when combined with translation/rotation (and patterns), merging coincident nodes and some other tools as shown here or in Matej’s new video.
Node coincidence indeed isn’t always needed, but I would say that it’s desired in the majority of the cases.
right, merging coincident nodes for single part is recommended to avoid any unexpected results due to some constraint or tied contact existed and collide with penalty contact. An original example is different case; it’s usually a baseplate with steel beam connected by welding.
i’m keep the face connected to conformal also, but sometimes not easily to achieved, not much testing in new feature of number element edge in mesh setting.
