# Incorrect displacement results with shell edge load on shell composite model
**URL:** <https://prepomax.discourse.group/t/incorrect-displacement-results-with-shell-edge-load-on-shell-composite-model/3359>\
**Created:** [March 21, 2026, 9:19am UTC](https://prepomax.discourse.group/t/incorrect-displacement-results-with-shell-edge-load-on-shell-composite-model/3359 "2026-03-21T09:19:54Z")\
**Showing post:** 7
**Post date:** [March 21, 2026, 3:59pm UTC](https://prepomax.discourse.group/t/incorrect-displacement-results-with-shell-edge-load-on-shell-composite-model/3359/7 "2026-03-21T15:59:08Z")
You could try relaxing the BCs - instead of fully fixing one edge, try applying sort of symmetry BCs (then you can fix one node in the vertical direction if needed). See this thread: [Cantilever beam with load at one end - #10 by CrisBab](https://prepomax.discourse.group/t/cantilever-beam-with-load-at-one-end/1241/10)
It’s also always good to solve 1/2, 1/4 or even 1/8 of the model if the geometry, supports, loads and evaluated responses allow the use of symmetry (with composites, you also have to make sure that the layup allows it).
_[View the full topic](https://prepomax.discourse.group/t/incorrect-displacement-results-with-shell-edge-load-on-shell-composite-model/3359)._
